Fuel at bottom of tank
simonlowther
Aircraft Type: C120
Post by simonlowther »
Hi guys,
How much fuel is remaining in your tank when the dipstick bottom is only just wet? I'm trying to figure out without draining the tanks.
Si
Simon Lowther
Cessna 120 (11102)
Re: Fuel at bottom of tank
If the wing had no dihedral the answer would be "none". Since it has a very low dihedral angle, the answer probably is "not enough to matter".
Post by 6277 »
Somewhere on this site is a graduated in inches dipstick device to measure the amount of fuel in your tanks. With a few gallons (3-4) in the tank, it's possible to unport the fuel outlet if you're in a prolonged bank or other attitude.
