Stromberg stumble, is this normal?
- Name: Dave Sprinkle
Hello everyone. I'm getting close to flying my 140. It's been down for about 2 years. Couple weekends ago, I started the engine for the first time in 18 months. It had a pretty bad misfire at idle, which I diagnosed to a clogged idle jet in the Stromberg carb. I cleaned out the jet and as a result, it now idles well, without a misfire. However, I've been unable to entirely eliminate a stumble if I open the throttle rapidly from idle. Is this normal? Or should I continue to diagnose other problems?
- Name: Mac Forbes
Re: Stromberg stumble, is this normal?
Dave, you'll likely get much more expert answers on this...but, that said: As best I can understand, when the Stromberg "transitions" from idle to run, there's a "normal" tendency for hesitation, especially if advancing the throttle rapidly. The fact that there's no accelerator pump may play a role, too. FWIW, mine has had a bit of hesitation similar for almost 38 years, even having had it overhauled a few times. (...good idea to refrain from quick throttle advance on final
) It's vital to keep it clean, of course, and good for you in finding and correcting the jet obstruction. It may not be related, but does yours have the mixture control set up for functioning? And, just a final thought (opinion) -- the Stromberg is probably the perfect carb for the C85/140. I like anything that reduces "unnecessary" complexities. Mac
Simple solution: don't do that.
As stated above, the carb doesn't have an accelerator pump. It uses what is called an acceleration well, which temporarily enriches the mixture, but its function is highly dependent on a number of different things, including the restriction of the air filter, the size of the air bleed jets, and the size of the holes in the emulsion tube.
Essentially, it was intended more for constant speed operation, not street racing.
When all is said and done, though, as long as it doesn't stall, it's not worth worrying about.
- Name: Mike Smith
Mac,2066 wrote: ↑Wed May 04, 2022 10:53 am Dave, you'll likely get much more expert answers on this...but, that said: As best I can understand, when the Stromberg "transitions" from idle to run, there's a "normal" tendency for hesitation, especially if advancing the throttle rapidly. The fact that there's no accelerator pump may play a role, too. FWIW, mine has had a bit of hesitation similar for almost 38 years, even having had it overhauled a few times. (...good idea to refrain from quick throttle advance on final) It's vital to keep it clean, of course, and good for you in finding and correcting the jet obstruction. It may not be related, but does yours have the mixture control set up for functioning? And, just a final thought (opinion) -- the Stromberg is probably the perfect carb for the C85/140. I like anything that reduces "unnecessary" complexities. Mac
You hit the answer square on the head. Fifty years ago, a gent in the business told me the same thing, because the unit has no accelerator pump it's common to get a stumble if the throttle is quickly advanced (kind of reminds me of friends operating some early jet engines when the fuel control was your hand or when operating a 5 cylinder Kinner radial, open the throttle too quick and the engine will stumble and hesitate).
Thanks, everyone, for your responses. I'm glad to know this is normal and that I can move on to another item on the Barriers to Flight list. Getting closer!
- Name: Tony
slight adjustments to the idle air mixture can help.
variations in fuel specific gravity can also effect this depending on how the float level is set. I had trouble with that last fall when I filled up with about 3/4 auto fuel.
N2395N
- Name: Mac Forbes
Good added point, Tony. I believe the STC may mention this, also (I'm too lazy to look uptonycondon wrote: ↑Thu May 05, 2022 1:00 pm slight adjustments to the idle air mixture can help.
