Floorboard inspection covers
8475
- Name: Dave Sprinkle
Hello everyone, my airplane has circular inspection covers on the floorboards just forward of the seats. I took them off and didn't see anything that might require inspection or service. Are these inspection holes common? Or was this a field mod for some reason?
2356
- Name: Huey Pilot
Re: Floorboard inspection covers
Those are not original.
tonycondon
- Name: Tony
Mine has the same. My plane also had weld repairs done to the gear after a ground loop around 50 years ago. Perhaps put in for access?
N2395N
I had a mouse nest in there, now I have an inspection cover...
Not original...........the only thing those access would be lost hardware when you're working on the rudder bars/brake master cylinders etc and loose hardware and it rolls down into that space where there "was" no access to get it out.........
Or........in John's case.........."Critter removal"
6298
- Name: Randy Thompson
I have one on the passenger side that I used to take pictures, back in the day when slides were the thing. Aerial Servey work..
