Changing Rubber Engine Mount Cushions
6277
Post by 6277 »
I need to change the rubber engine mount cushions, any tips? Raise the tail? Sequence? Thanks.
2356
Occupation-Interests: Retired
Re: Changing Rubber Engine Mount Cushions
Post by 2356 »
I have an O200 installed. I took the weight off with an engine hoist. I then replaced the rubber cushions one at at a time. C85 should be a little easier.
Aircraft Type: C-140 (sold)
Post by 8342 »
Raise the tail.
Use an engine hoist to relieve the pressure.
Post by 6277 »
Thanks. How high would you raise the tail. Five gallon bucket high?
Aircraft Type: '46 140 0-200A
Post by 6597 »
leveling the engine fore and aft makes it easier, think along the lines of when you weigh the plane, tail higher than a 5 gallon bucket, I think somewhere closer to 4+ feet.
It makes it easier, but it is not really critical. As close to level as practical. (Level is the splice plate that runs down the side of the fuselage behind the door posts.)
6277
Post by 6277 »
Got it...thanks to all.
6673
Post by 6673 »
Hi,
I'm wanting to change my bushings as well. I'm not sure where exactly to hoist the engine from. The only thing I've found is lift from "lifting eyes" on backbone of engine - I don't think I have that installed or lift from the crankshaft with prop removed (ref. OH manual). C-85-12F.
Thanks!
Nick
lifting eye.jpg (97.44 KiB) Viewed 2394 times
Post by 6597 »
https://www.fresnoairpartsco.com/produc ... e-lifting/
Fresno Airparts also has the correct crossbolts and spacers.
