Changing Rubber Engine Mount Cushions
- Name: Ray Hunter
I need to change the rubber engine mount cushions, any tips? Raise the tail? Sequence? Thanks.
2356
- Name: Huey Pilot
Re: Changing Rubber Engine Mount Cushions
I have an O200 installed. I took the weight off with an engine hoist. I then replaced the rubber cushions one at at a time. C85 should be a little easier.
- Aircraft Type: C-140 (sold)
Raise the tail.
Use an engine hoist to relieve the pressure.
- Name: Ray Hunter
Thanks. How high would you raise the tail. Five gallon bucket high?
leveling the engine fore and aft makes it easier, think along the lines of when you weigh the plane, tail higher than a 5 gallon bucket, I think somewhere closer to 4+ feet.
It makes it easier, but it is not really critical. As close to level as practical. (Level is the splice plate that runs down the side of the fuselage behind the door posts.)
- Name: Ray Hunter
Got it...thanks to all.
6673
Hi,
I'm wanting to change my bushings as well. I'm not sure where exactly to hoist the engine from. The only thing I've found is lift from "lifting eyes" on backbone of engine - I don't think I have that installed or lift from the crankshaft with prop removed (ref. OH manual). C-85-12F.
Nick
Nick
https://www.fresnoairpartsco.com/produc ... e-lifting/
Fresno Airparts also has the correct crossbolts and spacers.
