Not the correct antenna!
tomreneau
Aircraft Type: 1949 C140A
Post by tomreneau »
For a long time I thought I had two NOS original antenna for a Cessna 140A. Turns out they are both for a 170A instead. I highly doubt I will buy a 170A just so I can use the cool original parts. This means I am looking for the antenna for a 140A now. It is on pages 128-131 of the 1949-1951 Parts Catalogue and shows kit number 0511022-7 or w-106A for just the wire part. It’s worth a shot. Thanks, Tom
tomreneau
Re: Not the correct antenna!
Post by tomreneau »
Guess I’ll try EAA or Cessna Flyers forums.
phil123
Aircraft Type: C140-O200
Post by phil123 »
Looks like an ADF antenna, might be good for a museum display?
tomreneau
Post by tomreneau »
Needs to go on a restoration project!
That's a LF (Low Frequency) Radio Antenna. My second 140A, N9633A has the set up, but the previous owner whom I purchased the aircraft from took the mast off the cabin roof although the mast base is still there, and removed the wire that was connected from an insulator in front of the windshield. That wire was then routed up to the top of the cabin mast then to an insulator on a mast riveted to the top of the vertical fin.
elliotblock
Post by elliotblock »
Tom,
Is the antenna just longer? What's the difference?
Elliot
tomreneau
Post by tomreneau »
Yes. I’m betting I can alter it if need be.
