Jacking airplane
tomreneau
Aircraft Type: 1949 C140A
Re: Jacking airplane
Post by tomreneau »
Thanks for the stripaper advice. Airplane is low time so I doubt there will be an issue but we will be sure and look for the cracks at the steps. Thank you!
6277
Post by 6277 »
I removed a bent gear leg to replace it a while back. I made a cradle from a saw-horse and a cushioned fuselage shaped wooden support on the top of the saw-horse. I believe I was cautioned to tie down the tail due to the cradle being close to the CG? Just a thought.
Post by 6183 »
https://cessna120140.com/wp-content/upl ... 00x204.png
Member Randy Thompson makes and sells a very nice jackpad for the C-140 series.
thompsonsair@tds.net
Aircraft Type: 140A/C90-14F
Post by 8413 »
6863 wrote: Thu Dec 01, 2022 12:39 pm Randy's jack pad works well for me. I did glue some thin Walmart kitchen cutting board material to the surfaces to protect the gear leg paint. Regarding bottle jack use, I find the bottle jack adequately stable if I set the tail wheel on an upside-down bucket to give me a longitudinally level airplane.
I do something similar with Randy's jack pad...put a thick microfiber rag between the jack pad and the gear leg...no paint damage.
Josh
