"Adjusting" doors
cdoughty
"Adjusting" doors
Post by cdoughty »
One of my doors has a 1/4 inch gap at top-rear. This time of year it gives a nice cooling jet on my neck. I have tried new seals, adjusting the catch, and to spring it to be a little more curved on the back edge with no success. I've been cautious about springing it because I don't want to be posting in the for sale section looking for a new door. Just wondering if anyone out there has a secret fix?
Re: "Adjusting" doors
Look for a crack in the inner door skin near the latch. This allows the door to flex outward at the top. There is no adjustment. If you don't find a crack, I've heard of people installing a VW (bug) window latch in the upper corner to hold it shut.
Aircraft Type: 48 140 C90
Post by 6898 »
Ours does this too . I've heard that if theirs no relief outlet for air its got to go out somewhere? We have a closed baggage compartment and I wonder if there was a better outlet there it would exit the rear tail cone area instead of out the weakest part of the doors?
tdragger
Aircraft Type: 1946 C140
Post by tdragger »
Ditto here.
cdoughty
Post by cdoughty »
I'll have a look for the crack. Mine has the gap even on the ground so its not the awesome airspeed of my plane thats sucking the door open :D
6898 wrote: Wed Dec 21, 2022 10:19 amI wonder if there was a better outlet there it would exit the rear tail cone area instead of out the weakest part of the doors?
Actually, air flows up from the tailcone into the cabin. Blocking that path would only help in this situation.
