Just purchased 1946 140
chewie
Re: Just purchased 1946 140
Post by chewie »
frog wrote: ↑Wed Jan 11, 2023 12:36 pm If anyone has contact info for a Kevin Stokes, A&P and IA please send his contact info to me. Logbooks are MIA and he was the last mechanic to work on it. Not sure if that was in Oregon or Arizona.
Checking with my A&P now, he's worked in both OR and AZ.
Mark Johnson
Check the cognizant FSDO pages in the two states and you may find a listing of all the IAs in their data bases with all their contact info. I have done that in my FSDO and checked my name and also found a friends name who had dropped his IA some years ago. Only take a few minutes. FWIW PS start at FAA.gov
frog wrote: ↑Wed Jan 11, 2023 12:36 pm Logbooks are MIA and he was the last mechanic to work on it. Not sure if that was in Oregon or Arizona.
Wow! I missed that. I hope you find them, and that your purchase price reflected the fact they are missing...
There are 6 airmen called Kevin Stokes. Only one has a mechanic certificate, and he is located in Arizona. I've forwarded his address to you in a PM.
frog
Post by frog »
Thanks for all the leads
Also, go here and request a copy of the FAA records for your aircraft.
frog
Post by frog »
Thanks John, I did that and got a lot of valuable information
frog
Post by frog »
What do you guys recommend for registration and backlogs from the FAA. I will be hitting the 90 days in February. Do I need to start emailing now for an extension? Or wait until past 90 days?
frog wrote: ↑Thu Jan 19, 2023 8:15 am What do you guys recommend for registration and backlogs from the FAA. I will be hitting the 90 days in February. Do I need to start emailing now for an extension? Or wait until past 90 days?
Wait until it's close to 90 days then contact the FAA Registration Branch on the telephone not by email, and request an extension letter to your pending registration. Make notes of the individual's name you talk to in case you don't get the letter, and request that the FAA email you the letter. Make two copies of the letter, keep one with your aircraft records and put the other in the aircraft.
frog
Post by frog »
Thanks, I will do that. Seems crazy that they have the manpower to cash the check so fast, but can't type a simple document at the same time.
