Just purchased 1946 140
Re: Just purchased 1946 140
6597 wrote: ↑Thu Jan 19, 2023 10:45 am https://www.aopa.org/news-and-media/all ... ion-period
I'm trying to decipher this.....
I believe it's similar to politicians dealing with the debt level...basically, if there isn't sufficient time or resources for the prescribed period, just revise the prescribed period...again, and again(?) Hopefully this will, indeed, help with the backlogs and delays.
Yeah, not directly applicable to "Frog's" problem, but likely an attempt to help alleviate his situation.
Interesting side story: a few years back my registration came up for renewal. I paid my $2.00 or whatever it is and received a new certificate, which put in the plane. Recently, I received notification that it was again time to renew. I thought it had been less than the three year period, but went ahead and paid for and received a new certificate. When I went to the airport to put it in the plane I noticed both certificates, the new and the "old" have the same expiration date...
No wonder they are having trouble keeping up... Should I ask for a refund?
frog
Post by frog »
That's so terrible it's kind of funny
frog
Post by frog »
Does anyone have a picture of all the cables running to the back of the airplane it will be much appreciated. While taxiing around they rattle around like crazy, is this normal?
Aircraft Type: '46 140 0-200A
Post by 6597 »
Here ya go.
Maybe check your rudder return springs? Just a guess. They are under the cockpit tunnel, see the parts manual figure 20-9.
5-25-12 004.jpg (357.01 KiB) Viewed 9042 times
5-26-12 neutral.JPG (286.59 KiB) Viewed 9042 times
frog
Post by frog »
Mine look the same as yours, the second bulkhead in your first pic looks like it has a pad, or extra strip on it. Is it rubber or aluminum?
frog
Post by frog »
And thanks for the pics and advice on the springs
Post by 6597 »
Originals were a sort of phenolic compound.
frog
Post by frog »
Really enjoying flying the 140
6478
Aircraft Type: Cessna 140
Post by 6478 »
Where was this taken? Looks like fun!
Dean DeRosia
N81L
1946 Cessna 140
Glendale, AZ KDVT
