Scott 3-24B Tailwheel Questions
tomreneau
- Name: Tom Reneau
- Aircraft Type: 1949 C140A
I have two questions. First I am replacing the TW springs and chains. I purchased the U2151A-000 assembly from Spruce and the chain is larger links than original and the spring is slightly larger. Anyone know if there is a better match or method to replace the assembly? Part numbers if you know would be appreciated. Second is I want to replace the rubber in the TW leaf assembly and wonder if anyone knows what would be the correct rubber to use. Thanks for the help as always. TomR
scotts97385
Re: Scott 3-24B Tailwheel Questions
Check the Neal Wright Technical Articles at the bottom of the forum pages, the info you need may be there.
