Render and print of my interpretation of the Neil Wright mixture arm.
Does anyone know how to upload a .step file? That would allow one to machine after passing through a CAD or CAM program on a CNC mill easily. Protolabs can probably also make relatively cheaply.
Stromberg Mixture Control Arm Extension
edidin
Re: Stromberg Mixture Control Arm Extension
- Wright Mixture Extension Render,jpg.jpg (25.05 KiB) Viewed 1397 times
- Wright Mixture Extension Print.pdf
- (49.17 KiB) Downloaded 414 times
wingspinner
- Name: Ron Curry
- Aircraft Type: c140
Thanks for the 3d rendering. I’m pretty sure you can upload most any file if you change the suffix to .jpg or .zip or something else the forum accepts. Haven’t tried it here but that works on some forums. Of course, whoever downloads it will then have to rename it back to .step (in this case) once they get it on their computer.
