Tailwheel Rivets
pabloj3
Tailwheel Rivets
Post by pabloj3 »
Hello everyone,
I found these rivets on the tailwheel coming apart. They rivet from the bottom up through the tail, a bracket, and into the top stiffener. Do you happen to know what rivets are used/supposed to be used here? I couldn't find that in the IPC or anywhere else.
I appreciate the help, as always!
Cheers,
Pablo C. Branco
Re: Tailwheel Rivets
Pablo,
Let me see if I can get you an answer. I know someone that is very familiar with that tail wheel bracket.
pabloj3
Post by pabloj3 »
Thank you!!! That would be great.
V529 wrote: Thu Sep 07, 2023 7:53 am Pablo,
Still working on this. My source must be traveling. No reponse yet. If I don't get anything in the next day or two, I'll see him in person sometime next week. Maybe consider a -5 countersunk rivet. Just a regular AD rivet, I don't know as they have to be anything special. I'll get you an answer.......it may take a bit.......
Are there any markings on the factory head?
With all that ferrous metal in there a monel rivet might be the right answer.
pabloj3
Post by pabloj3 »
No worries!!! I appreciate you trying.
V529 wrote: Fri Sep 08, 2023 11:29 am . No reponse yet. If I don't get anything in the next day or two, I'll see him in person sometime next week. Maybe consider a -5 countersunk rivet. Just a regular AD rivet, I don't k
pabloj3
Post by pabloj3 »
I am not sure! Don't think so. Let me see if I can find a marking.
6643 wrote: Fri Sep 08, 2023 12:42 pm Are there any markings on the factory head?
It looks like some kind of pop rivet was installed.
Maybe it is the camera angle?
I am sure they are not supposed to be pop rivets.
Pablo,
Ok, I spoke with David, he rebuilds these units regularly. Just install a regular countersunk rivet. size as required, Nothing special.
I would put a generous coat of chromate primer on the rivet and install it wet to help prevent dissimilar metal corrosion between the steel parts and the aluminum rivet. I try to prime anything where there is ferrous metal in contact with aluminum.
