Scott 2000 Tailwheel Bearing Cup Replacement
Post by 6930 »
Hi Folks,
What is the easiest way to replace the cup and spacer in a Scott 2000 tailwheel hub? I assume heat up the hub then tap out the old cup and spacer? Then, to reinstall, heat the hub (maybe cool the cup and spacer?) and drop them in? Any tricks to be aware of?
Mike Pastore, N2635N
Naper Aero, LL10
Re: Scott 2000 Tailwheel Bearing Cup Replacement
Pretty straightforward. You have the basic idea down. I have in the past taken the bearing races out and put them in without changing temps. (heating wheel etc)
Yes, if you use heat then use it sparingly. Too much heat will change the metallurgy of aluminum.
6930
Post by 6930 »
Thanks Vic and John,
Yup...worked like a charm. Appreciate the input!
Naper Aero, LL10
