A Tale of Two Tires
A Tale of Two Tires
Post by 6930 »
I just replaced my tailwheel bearings on my Scott 2000 and though I originally wasn't going to replace the tire, I ended up doing that too. One thing that bugged me about the tire that was mounted (I put it on about 4 years ago, new from Aircraft Spruce) was that it wasn't bound tightly by the wheel hubs and could spin on the wheel after assembly.
When I was looking on the Univair site for new bearings I saw a picture of the "same" tire which had "nubs" inside which obviously were meant to lock the tire to the wheel. I ordered the Univair tire and sure enough they fit like a champ. Nice and tight. Pictures of the two tires attached. Thought I would share for those that are thinking of replacing the tires. There seems to be two versions out there one of which is not right.
Correct Tire.jpg (81.56 KiB) Viewed 2673 times
Incorrect Tire.jpg (87.39 KiB) Viewed 2673 times
Mike Pastore, N2635N
Illinois State Representative
Naper Aero, LL10
