Finally got my axles from Grove, and finally got around to this project. I have to say it was a lot easier than I was expecting, but also had a few curve balls.
I ended up having to rebuild both calipers and the right side master cylinder. I'm glad I did though as they were both pretty dirty/gunky. The braking system is surprisingly simple and easy to work on. After rebuilding I also installed new brake lining and rotors. With a clean braking system it was very easy to bleed the brakes from the caliper. I just pressurized it with a little bottle and filled the system up to the masters.
I did a test flight today and everything was great. I did a few high speed taxis first to get a feel for it and break in the new brakes. The tail comes up much faster now, and the short field performance improved with the little bit of added AoA. Even with the O-290-D up front, I never felt in danger of burying the nose into the ground, yes it's a little more sensitive, but still very controllable.
Thanks everyone for the help on this project, it made it very easy. If anyone else wants to tackle this and has any questions feel free to ask!
- grove_install_01.jpg (189.63 KiB) Viewed 10045 times
I do have one question here, what are you guys using to tie the line to the gear leg? There isn't enough space to use a clamp, I noticed some of you had a piece of hose and a zip tie?
- grove_install_02.jpg (168 KiB) Viewed 10045 times
