Tailwheel
- Name: Randy Thompson
Re: Tailwheel
It depends on the type of tailwheel. You should be able to find the installation instructions for the one you have.
Re: Tailwheel
Yeah, that.
If it's a Scott 3200 then you want no slack and minimal tension. If it's a Scott 2000 or the 3-24B then tension is required. I think the number is 20 lbs, but that's from memory, so don't quote me.
huntair1
Re: Tailwheel
Thx
huntair1
Re: Tailwheel
My tailwheel is 2.80 x 2.50 ( specialty tire of America). Would this be the same as a Scott 3200?
Re: Tailwheel
That tire is used on several tailwheels, the Scott being one of them. Post a picture of the whole assembly.
