Felt Engine Baffling
tomreneau
- Name: Tom Reneau
- Aircraft Type: 1949 C140A
My aircraft has covered felt for engine baffling which is attached with staples. At some point a piece was replaced with new material and pop rivets. Id like to go back to original with that small piece. Anyone have an idea on sourcing the material and the staples? Thanks.
tomreneau
- Name: Tom Reneau
Re: Felt Engine Baffling
Contact John Von Linsowe
https://www.linkedin.com/in/john-von-linsowe-3262a112
If memory serves me correct John found a source for the original type engine baffle seal that he utilized on his airplane.
https://www.wagaero.com/cowl-seal.html
This is the Wag Aero equivilent I had for awhile, looks similar to what you have. May not be 'original'.
https://www.brownaircraft.com/cowl-vent ... e-s/73.htm
This is the Brown Aircraft material.
David, now that you mention Brown Aircraft, I do think that's where John purchased the material when he re-did his C-140.6597 wrote: ↑Fri Dec 01, 2023 8:41 am https://
Good work, and thanks David!
Just a feeling, but it wouldn't surprise me at all if those were the same part.
