PMA Fuel Selector Install in 140A
Post by 5060 »
Has anyone installed the PMA Sierra Hotel Aero -140A Fuel selector in a 140A?
Following the issues trying to repair the original valve, owner decided to go with the new selector. Any experiences, and fittings used to make it fit the aircraft would be appreciated.
Re: PMA Fuel Selector Install in 140A
From their website, looks like some tube bending so not a drop in replacement, see Left-Right-both-Off pic
https://www.sierrahotelaero.com/pma-sel ... alves.html
5149
Aircraft Type: 1948 140
Occupation-Interests: A&PIA
Post by 5149 »
I have install a couple, pretty straight fwd.
Cheers!
Tim
Tim Mix
NC2404V "The Arctic Tern"
Oregon State Rep
Mix Aircraft Solutions, llc @ Mulino State Airport (4S9)
Aircraft Type: 48 140 C90
Post by 6898 »
Installed in our 48 140 in 2010 pretty straight forward , definitely a big improvement.
Aircraft Type: 140A/C90-14F
Post by 8413 »
Am I correct that the Sierra Hotel fuel selector doesn't need a field approval since it's PMA and is not a minor or major modification of the fuel system?
Josh
8413 wrote: ↑Fri Mar 29, 2024 8:18 am Am I correct that the Sierra Hotel fuel selector doesn't need a field approval since it's PMA and is not a minor or major modification of the fuel system?
Josh
Correct. A PMA approved replacement part can be installed with a log book entry.
