Partial power loss
6863
Re: Partial power loss
Post by 6863 »
The vary same engine symptoms happened to me in 1983 - in a brand new diesel truck with saddle tanks. Even the dealer couldn't figure it out. As I was filling the right hand tank I happened to see a rag float by past the fuel nozzle. With an intricately formed coat hanger I was able to snag that rag after which the truck ran beautifully.
John Kliewer
mikeacro
Occupation-Interests: Retired Corporate Pilot
Post by mikeacro »
That’s crazy. Today I did a borscope inspection on the other tank and it appears to be clear of “dish towels”. I then checke the carburetor inlet screen and found it almost completely blocked. I’m amazed it ran at all. Clearly the IA that performed the annual did not check this screen ( among many other items ) one of my favorites was the rear aileron cables that were sawing not the fuselage on both sides. Clearly, he didn’t remove the inboard fairing on either side.
Buy a lottery ticket!
mikeacro
Post by mikeacro »
That may be a good idea John!
Cheers, Mike
6643 wrote: ↑Sun Mar 31, 2024 5:18 pm Buy a lottery ticket!
John, have you talked to Jerry and Marge Selbee from Michigan? Jerry figured out the lottery.
6183 wrote: ↑Tue Apr 02, 2024 8:08 am John, have you talked to Jerry and Marge Selbee from Michigan? Jerry figured out the lottery.
I don't need to win the lottery. I'll be making a fortune off the tolls from the bridge in Brooklyn I just bought from a Nigerian Prince.
6643 wrote: ↑Tue Apr 02, 2024 4:53 pm
Good one John, Good one.
On another note, I'm leaving for Sun-N-Fun on Friday to help in the type club tent for the Association, I'll give the Ercoupe guys your best.
Mike
