Maule tw zerk
vindio
Aircraft Type: C120
Maule tw zerk
Post by vindio »
Greetings! New C120 owner here (first post).
Our tailwheel grease fitting/zerk has gone missing. Does anybody know the part #/size to replace it with? I've attached a picture we took right before the zerk departed the airplane.
(alternatively, is this a suitable replacement for the whole plate+zerk assembly? https://www.wagaero.com/wheels-brakes-t ... pma-d.html)
Thanks in advance!
cdoughty
Re: Maule tw zerk
Post by cdoughty »
Mine was bent like that and just screwed into the thin hubcap. I replaced with one from Napa with 1/4 28 threads and put nut on backside. Working fine 600 hrs. The clearance on the back is very tight, but it does clear the axel nut.
vindio
Aircraft Type: C120
Re: Maule tw zerk
Post by vindio »
cdoughty wrote: Sun May 05, 2024 5:57 am Mine was bent like that and just screwed into the thin hubcap. I replaced with one from Napa with 1/4 28 threads and put nut on backside. Working fine 600 hrs. The clearance on the back is very tight, but it does clear the axel nut.
Thanks! I went ahead and purchased the one from Napa, but found that, even properly torqued, etc, it still leaks grease, as the opening through the hub cap is now oversized. Looking to purchase a replacement hub cap, but unfortunately, Wag Aero has gone out of business (and Aircraft Spruce doesn't yet list the part). Right now, we have duct tape covering the opening, and that seems to be doing the trick.
Back to he drawing board ...
Re: Maule tw zerk
Call them up. Tell them you need the hub cap for a Maule SFSA-1-4, item 18 in the parts diagram.
(Seems ACS now has a monopoly on Maule parts...)
Aircraft Type: 48 140 C90
Re: Maule tw zerk
Post by 6898 »
Welcome and thanks for using the forum ,You will definitely find the people that can answer all here. Plan to attend the technical forum at Oshkosh and our annual convention in northern Illinois to meet and great the group.
vindio
Aircraft Type: C120
Re: Maule tw zerk
Post by vindio »
Well, we replaced the whole hubcap with a new part from Aircraft Spruce, and about 30 flying hours later, the zerk fell off again (see pic). Second departed zerk in less than 100 hrs.
Our workaround is to simply grease-pack the bearing by hand (by completely removing the cap), and then, after re-installing the cap, we'll permanently cover the zerk hole with some heavy duty duct tape.
Does anybody have a more elegant solution? :-)
v
Re: Maule tw zerk
What does the zerk screw into? Try some red loctite. Or, can you put a nut on the back side? (Or both...)
