Hello all,
What is everyone using for CHT/EGT indication? I currently don’t have anything installed in the plane and would like to get some kind of EMS system to monitor EGT/CHTs. What are you all using if any?
Matt
CHT/EGT Indication setups
- Aircraft Type: C120
- Name: Bradley Bell
Re: CHT/EGT Indication setups
I'm like you, nothing, nada, zip on the little c85-12.
- 8413
- Name: Josh C
- Aircraft Type: 140A/C90-14F
I have an EGT on cylinder 1. I don't find it to be of much use. I find that leaning until it starts running rough then richen till smooth works just fine and is quicker than watching EGT numbers on a gauge. I would rather have CHT on the hottest cylinder if I wanted to monitor anything.
Josh
Josh
