C-140 CFI NW Ohio
C-140 CFI NW Ohio
Hi All,
I need to find a CFI in the Northwest Ohio/ Southeast MI area.
Insurance requires 10 hours in make and model. Cessna 140.
I purchased an out of Annual C-140 that is located on a private strip and need to get it moved to a location so that the Annual can be done.
Once the Annual is done will I need 5 hours dual for insurance purposes.
If you know of someone interested you can post it here or PM me.
Re: C-140 CFI NW Ohio
8342 wrote: Wed Oct 17, 2018 10:32 am I ... need to get it moved to a location so that the Annual can be done.
In order to move it legally (without taking it apart) you'll need a ferry permit. To get a ferry permit you'll need an IA to sign it off as airworthy. It might be easier and cheaper to have it annualed where it is.
Thanks for the information.
I am and A&P and have already made arrangements to get a Special Flight Permit.
Aircraft Type: 48 140 C90
Post by 6898 »
looks like there are 5 cfi's in Ohio and 5 in Mich. Do you have a members Assc. directory? if not 815 695 9970 CST M-F Good luck Jeff
Thanks Jeff, I may have found someone but will use your info for a backup.
Thanks for all,
I've been out of town for the past week and just saw this. We have a couple of pretty active members in NW Ohio. Did you find someone?
529 wrote: Wed Oct 24, 2018 7:59 pm I've been out of town for the past week and just saw this. We have a couple of pretty active members in NW Ohio. Did you find someone?
Yes, thank you.
6643 wrote: Wed Oct 17, 2018 10:54 am
For future reference, an IA is not need to get a Special Flight Permit (Ferry Permit).
Go to the FAA website and download Form 8130-6.
Complete required sections.
Fax it to the FSDO who has jurisdiction of the departure airport.
If they like it, they will fax or email your approved permit along with a list of restrictions.
These include a sign off by an A&P in the maintenance logbook certifying AD compliance and safe for flight.
8342 wrote: Thu Nov 15, 2018 6:01 pm For future reference, an IA is not need to get a Special Flight Permit (Ferry Permit).
You are correct. However, unless you can find an A&P who is familiar with that particular aircraft, I'd expect whoever is signing it off would want to do the equivalent of a 100 hour (same scope as an annual) inspection before signing it off. Might be easier to get an A&P than an IA, though.
