Wing tank sump material ring.
redbud40
Aircraft Type: C-140,RV6A
Occupation-Interests: Retired Military, Airline Pilot
High School Volunteer Aviation dept
CFII
Post by redbud40 »
I have attached to the skin around the wing sump a circle of material that looks like it was originally put on with adhesive.
I am planning on replacing the valve and want to be prepared to replace this material as well if it comes off. ( which I think will as it is already peeling off a little )
Is this a regular part or some fabricated piece for support or something.
Thanks.
redbud40
CFII
Re: Wing tank sump material ring.
Post by redbud40 »
8281
Post by 8281 »
It looks fabricated to me !
I'll look tomorrow at the wing parts that I have on hand
and let you know what I fine!
John
8281
Post by 8281 »
From what I have found, there is just a hole in the bottom wing skin
where the fuel tank drain is located / And there is no other material
involved!
This is all most folks have....
