Eisemann ground terminal advice
dcannon
Aircraft Type: 1946 C120
Post by dcannon »
Failed mag check at ground run after my annual and confirmed it is a short in the wiring harness leading back to my toggle switches. (Runs great with the P-lead ground terminal disconnected so no issue at the magneto). Wiring has a variety of damage so time to replace.
Screenshot 2024-12-13 at 5.20.55 PM.png (665.74 KiB) Viewed 4774 times
These are Eisemann LA-4s and I plan to use shielded 14 gauge Mil-27500 wire. Seems my options are:
1) De-solder these Eisemann ground terminals and reuse them (is this even compatible with MIL-C-27500?). Requires soldering at "B" in the attached diagram from the Eisemann manual.
Screenshot 2024-12-13 at 5.16.55 PM.png (172.12 KiB) Viewed 4775 times
or
2) Use P/N 10-52306 ground terminals (https://www.fresnoairpartsco.com/produc ... minal-kit/). Can anyone confirm if this terminal is compatible with the Eisemann LA-4?
I think I prefer number 2 unless there are advantages or compatibility issues I am not considering. The 10-52306 seems a more modern approach.
Re: Eisemann ground terminal advice
Have you asked Fresno? That's where I would start. (It's a Bendix part number, so I'd say chances are good it will not work.)
dcannon
Post by dcannon »
Thanks John, I can do when they open Monday. I had already missed them on Friday.
Bogert Aviation lists that Bendix terminal as being common to most mfg including Eisemann so it seems a decent chance it will work.
7698
Aircraft Type: C120 - GAKVM
Post by 7698 »
Used this braiding and a 16AWG cable with my Eisemanns with no problems.
https://www.lasaero.com/products/article/N04EI2CCT
Uk supplier, but pretty sure this will be available state side. :D
dcannon
Post by dcannon »
For future reference, a few findings:
P/N 10-52306 (AN3105) does not work for the Eisemann LA-4 as John had surmised. For the LA-4 the insulator and spring are far too long. The nut, however is the same thread if that helps anyone.
The ground terminal assembly in the Eisemann catalogue is P/N H27-525, but it might as well be unobtainium.
I desoldered my old ground terminals and used MIL-C-27500 14 AWG. I just followed the Eisemann manual, pretty easy.
