Wing Root Rubber Fairing
redbud40
Aircraft Type: C-140,RV6A
Occupation-Interests: Retired Military, Airline Pilot
High School Volunteer Aviation dept
CFII
Post by redbud40 »
Wanting to replace the rubber fairing pieces at the wing root. I have seen a previous post on attaching and maybe using Spruce for the pieces. None of the pieces on Spruce look like what I have. Has anyone done this recently , and if so what product or rubber part did you use to replace. This is what mine looks like now.
Thanks.
dcannon
Aircraft Type: 1946 C120
Re: Wing Root Rubber Fairing
Post by dcannon »
My wing root fairings only have felt on the inside leading edge to protect the glass. There is no rubber or material visible on the outside.
redbud40
CFII
Post by redbud40 »
After closer look at the parts manual it looks like forward cuff does use felt. I was looking for rubber since that is on there now. Anyone know what thickness I might consider. The part number for forward felt is not coming up with anything that I see. Spruce has self adhesive felt 1/16 inch that might work. Interesting why this rubber was added who knows how long ago.
A lot of people use something like this:
https://www.aircraftspruce.com/catalog/ ... -01300.php
