Hello,
I am looking for a source to buy a new 150 / O200 style exhaust.
I am aware that the appropriate braces are different for the 140.
Is there a document showing the details for this replacement?
Thanks for any advice !
Kind regards
Horacio
C 150 EXHAUST TO REPLACE OLD SYSTEM
5469
- Name: Horacio Berardone
Horacio Berardone Bouhébent
LV-NGL 1946 C140 SN 10.260.
Re: C 150 EXHAUST TO REPLACE OLD SYSTEM
Chief Aircraft had what I needed a few years ago when I had to replace my LH C-150 muffler. I had all the other bits like heater shroud and tailpipes, which Chief seems to have also. I am assuming you will perhaps contact Ken and Lorraine Morris who have the active STC for the 150 exhaust installation? Crossover brace pics below, attached to a stud on the oil tank and by straps on the exhaust down spouts.
https://www.chiefaircraft.com/wc-8300-3.html
https://www.chiefaircraft.com/wc-8300-4.html
- exhaustmount.JPG (108.21 KiB) Viewed 18818 times
5469
Thanks so much, David.
Great information, I didn't know that Lorraine and Ken were the holders of that STC.
Of course I will be in touch with them !
Have a nice week end,
Horacio
Tks for the pics and details.
Horacio
6641
- Name: Joe H
- Occupation-Interests: A&P IA Ret.
For what it's worth I've had good luck with the old wag aero stc'd exhaust kit.
It came with the tail pipes but not the brackets.
I think Wag Aero got absorbed by Aircraft Spruce
- Name: Mike Smith
Hola Horacio, No conozco las partes legales de los requisitos de aviación en Argentina, ¿se requiere un STC (Certificado de Tipo Suplementario) para las modificaciones de aviación en su país? Si es así, Lorraine Morris puede ayudarlo con eso, pero aún necesitará los materiales necesarios para cambiar al sistema de escape Cessna 150. He tenido muy, muy buena suerte con Wentworth Aircraft Salvage aquí en los Estados Unidos. Puede ponerse en contacto con ellos por correo electrónico, www.wentworthaircraft.com y preguntarles si tienen el material que está buscando. ¿Sabes exactamente lo que vas a necesitar? Si la respuesta es no, envíame un memorándum y te enviaré la lista de los artículos necesarios.
Mike y Dianna
Mike y Dianna
