ADS-B out….no transponder
Occupation-Interests: Flight paramedic
Post by 6991 »
So I sit here contemplating travels in my 140. It is quite close to original other than an upgraded radio. I do not have a transponder, so obviously no encoding altimeter. What have you done to make your aircraft ADS-B out compliant when in this situation? I’d love to plan for the convention in MO, but without a ADS-B out this is not an option.
Joe
Joe Belany
2470V
Esmiol
Aircraft Type: C120
Re: ADS-B out….no transponder
Post by Esmiol »
My understanding if you need one you need both for the airspace.
Can’t you stay outside the mode c vail to get there?
VIP620
Name: ken tengesdal
Aircraft Type: 120
Post by VIP620 »
not sure, can one land outside and one so equipped come out to you and do a formation fly in
Take a look at Title 14 Code of Air Regulations 91.225 (g) (www.FAA.gov)
Operations within areas whereby ADS-B is required can be allowed if:
Requests for ATC authorized deviations from the requirements of this section must be made to the ATC facility having jurisdiction over the concerned airspace within the time periods specified as follows:
For operation of an aircraft that is not equipped with ADS-B Out, the request must be made at least 1 hour before the proposed operation.
According to regulations it is possible for you to attend the upcoming convention even without ADS-B if you make the proper requests as outlined in 91.225 (g).
Aircraft Type: 48 140 C90
Post by 6898 »
Hope you find a solution if not drive. Conventions are good time to meet others with the same hobbies. Jeff
I reached out to John G. who's the convention host about the possibility of attending the Creve Coeur convention without ADS-B.
He is going to reach out to the local St. Louis approach/departure facilities and see if there is an acceptable path to get non radio aircraft in and out of the St. Louis B airspace.
A couple ideas that come to mind is:
A. landing at an airport close to the Class B and calling the facility via phone.
or
B. perhaps a bud can meet you outside the B veil and you can fly together as a flight of two.
In the mean time, you may want to look at this information:
ADS-B deviation plan
https://www.aopa.org/advocacy/ads-b-adapt
8425
Post by 8425 »
I got a contact today for an inspector in the local FSDO, so will try to work an approach to get a group waver, (if possible). Even if they,(the FAA), provide a waiver for ADS-B, which is possible, I do not believe they can waver the lack of a transponder/mode-c. If you have one of the very few 120's that has never had an electrical system, then no transponder/mode-c is required. We have a number antiques in the Creve Coeur area that operate in this fashion.
John Groeneveld
8425
Post by 8425 »
I have been talking to the FAA FISDO about options for non-ADS-B equipped and/or non-transponder mode-C equipped aircraft to get to 1H0 under the class B veil. So far they seem to be willing to work with us. Their first question is how many non-equiped aircraft are we thinking will fly in if we develop a process.
So I need to get a reasonable guess at;
A) The number of aircraft without transponder/mode-C.
B) The number of aircraft With transponder/Mode-C, but Without ADS-B
I need to get this estimate back the team that is looking into this as soon as possible.
I think this FAA team is looking for a way to allow as many aircraft to participate in the convention as possible, while working within the existing regulations.
John Groeneveld
6991
Post by 6991 »
I'm not sure how to estimate numbers until you get closer to convention time. I know I appreciate the time you have put into this topic.
As I near retirement and am looking at taking more adventures my question was how to solve the no ADS-B out issue, using the convention as an example. I'm not sure $8k-10k for a radio in my 77 year old airplane is the most fiscally responsible idea out there and was hoping to identify a more cost effective plan.
Joe
Joe Belany
2470V
