Cessna electric panel clock
dcannon
Aircraft Type: 1946 C120
Post by dcannon »
What is this hole for on the back? I don't have one at hand right now to get a light on it.
I've got one that will run if I give it a tiny bit of twist pressure on the adjustment knob. Otherwise with 12V it doesn't run. Im guessing it's just enough gummed up internals that the motor won't scoot.
Screenshot 2025-05-20 at 1.08.48 PM.png (298.41 KiB) Viewed 3046 times
Re: Cessna electric panel clock
Most of those old clocks are actually wind up mechanisms with a little electric solenoid that winds it every time it unwinds enough to close a set of contacts.
Not sure about the hole, maybe an adjustment screw?
Post by edidin »
Easy to get the wind-up clock from eBay or new ones from Waltham Clock. Very satisfying bit of mechanical kit.
dcannon
Post by dcannon »
Thank you both. I agree mechanical is more satisfying. I went with a Wakmann. I did not know about Waltham - great find!
