SL 77-6
Re: SL 77-6
I only have the revised SEB92-27 later version. What are you trying to find out? Below are some gas cap 'readings' from Neal Wright that might interest you.
https://www.cessna120140.com/Forum2018/ ... f=10&t=138
https://www.cessna120140.com/Forum2018/ ... f=10&t=106
https://www.cessna120140.com/Forum2018/ ... f=10&t=103
kduck
Re: SL 77-6
Thank you very much for your reply, will read these.6597 wrote: ↑Tue Jul 29, 2025 11:42 am I only have the revised SEB92-27 later version. What are you trying to find out? Below are some gas cap 'readings' from Neal Wright that might interest you.
bc12d
Re: SL 77-6
I have found the Half vented unauthorized 140A fuel caps on my C140, not yet flown but will be replaced with the original caps. Thanks for posting the info.
Re: SL 77-6
Here's another article I found from Neal....
- Gas Cap Problem Article.pdf
- (87.14 KiB) Downloaded 596 times
