OK, that's an older form 337. Does it have anything written on the back?
Metalized Wing fuel tank cover
Re: Metalized Wing fuel tank cover
- dcannon
- Name: Dan Cannon
- Aircraft Type: 1946 C120
Yes, form ACA-337 (4-52). On the back is block 8, description of work accomplished. It contains a weight and balance table and the text "Fabric removed and 020 metal installed"
- 6843
- Name: Dave Sirota
Dan, Did you have a chance to look to see if the portion (about 3/8") of the tank cover that slides underneath the fuselage top skin is riveted to the butt rib on your plane?
Dave
Dave
Dave Sirota
'46 C-140 N89654
'96 Hatz N24B
KRYN
'46 C-140 N89654
'96 Hatz N24B
KRYN
- dcannon
- Name: Dan Cannon
Dave, my apologies. Forgot, then got busy, haven't been to the hangar in a while. Im trying to visualize what you are describing. Ive never had the tank cover off in the few years Ive owned it. Cover does slide under inboard panel but confirming whether it is then riveted to the rib I think would require some disassembly?
Does this image help? All PK screws securing the cover
- dcannon
- Name: Dan Cannon
PS Can I get you this info by removing the wing root fairing?
- 6843
- Name: Dave Sirota
Dan,
Wow! your plane looks great! I don't think you can see anything by removing the fairing. If their were rivets, unless they were flush rivets, you'd see the cabin skin sit off the surface of the wing by the height of the rivet heads. I don't see that in your pictures so I'm thinking it's not riveted. I'm thinking more and more about using machine screws but still haven't convinced myself cutting the threads won't cause spar cracks down the road.
I appreciate your sending the pictures.
Dave
Dave
Dave Sirota
'46 C-140 N89654
'96 Hatz N24B
KRYN
'46 C-140 N89654
'96 Hatz N24B
KRYN
- Name: Ken Kelley
- Aircraft Type: 120
The 1946 140 I used to own had metalized wings before I installed fabric wings sometime later. The fuel tank covers were attached with screws and the panel slipped under the top skin of the cockpit. The skin was drilled at each screw location with an oversized hole to allow removal of the screws and panel without removing the wings.
