High Oil Temperature
Re: High Oil Temperature
I have to agree, if the only thing that changed was the mags then it must have something to do with ignition.
6643 wrote: Wed Jul 16, 2025 11:29 am I have to agree, if the only thing that changed was the mags then it must have something to do with ignition.
Ditto, check what was "changed last"
Post by edidin »
Trust but verify your mechanic's timing with the new mags. Also check that all the leads are going to the correct plugs and/or are in good condition. On the little Continentals, one mag fires the top plugs, the other the bottom. And they are two degrees off in their firing BTDC in the C-85.
It's really the only thing that you touched that could affect temps based on the actions in the orignal post. This assumes that historically your oil temps were the standard OAT + 100-110 degrees F.
2718
Post by 2718 »
Findings/Solution:
1. Large baffle between #1 and #3 flopping up and down/Tightened up w/safety wire.
Oil temp dropped from 225 to 210.
2. Small baffle between #2 and #4 bent.
3. Support plates worn.
4. Replacing all baffles and support plates. Spring clip availability and price questionable.
5. May add blast tube in the future.
Amazing how critical/sensitive the intercylinder baffles are.
Huge thank you to John Cooper and his initial suggestion.
Post by edidin »
Just chiming in to check the timing again - trust but verify. Your mechanic's 140A had a C90 which has slightly different timing from the C85. According to TCDS (check this of course), C90 is 26 degrees Top, 28 degrees Bottom; C85 is 28 degrees Top, 30 Degrees bottom. On all the small Continentals one mag fires the top plugs and the other the bottom plugs.
Basic rule is that a C85 runs OAT +100-110 degrees. So at 70-80 should be around 190 at most (and likely lower).
2718
Post by 2718 »
Thanks.
Checked timing twice. It is correct. Even tested spark plug leads.
No ignition issues.
Not to beat a dead horse, but, left mag (as seen from the pilot's seat) fires all four lower plugs and is timed at 30 BTDC, right correct?
2718
Post by 2718 »
Hellow John,
If anyone has a right to beat a dead horse it is you.
Left mag firing lower plugs at 30 degress and right mag firing top plugs at 28.
Thanks again!
2718 wrote: Thu Aug 28, 2025 8:25 pm Hellow John,
Thanks again!
John's been "floggin' four leg critters fer years"! ;)
