High Oil Temperature
Re: High Oil Temperature
I have to agree, if the only thing that changed was the mags then it must have something to do with ignition.
Trust but verify your mechanic's timing with the new mags. Also check that all the leads are going to the correct plugs and/or are in good condition. On the little Continentals, one mag fires the top plugs, the other the bottom. And they are two degrees off in their firing BTDC in the C-85.
It's really the only thing that you touched that could affect temps based on the actions in the orignal post. This assumes that historically your oil temps were the standard OAT + 100-110 degrees F.
2718
Findings/Solution:
1. Large baffle between #1 and #3 flopping up and down/Tightened up w/safety wire.
Oil temp dropped from 225 to 210.
2. Small baffle between #2 and #4 bent.
3. Support plates worn.
4. Replacing all baffles and support plates. Spring clip availability and price questionable.
5. May add blast tube in the future.
Amazing how critical/sensitive the intercylinder baffles are.
Huge thank you to John Cooper and his initial suggestion.
Just chiming in to check the timing again - trust but verify. Your mechanic's 140A had a C90 which has slightly different timing from the C85. According to TCDS (check this of course), C90 is 26 degrees Top, 28 degrees Bottom; C85 is 28 degrees Top, 30 Degrees bottom. On all the small Continentals one mag fires the top plugs and the other the bottom plugs.
Basic rule is that a C85 runs OAT +100-110 degrees. So at 70-80 should be around 190 at most (and likely lower).
2718
Thanks.
Checked timing twice. It is correct. Even tested spark plug leads.
No ignition issues.
No ignition issues.
Not to beat a dead horse, but, left mag (as seen from the pilot's seat) fires all four lower plugs and is timed at 30 BTDC, right correct?
Hellow John,
If anyone has a right to beat a dead horse it is you.
Left mag firing lower plugs at 30 degress and right mag firing top plugs at 28.
Thanks again!
Thanks again!
