Maule Tailwheel Failure / Scott 3200 Replacement Parts
vindio
Aircraft Type: C120
Post by vindio »
Hello all,
Looking for all the parts required to swap from a maule tailwheel to a Scott 3200. We just had our leafspring on our maule tailwheel collapse on landing so I'm thinking this is a good time to make the switch. I've included screenshots of what's in the cart now.
Re: Maule Tailwheel Failure / Scott 3200 Replacement Parts
Not an answer to your question, but, could you tell me if this plane has extenders on the front wheels?
Looks like there's a few parts missing where the bolt holds the front of the springs to the tail wheel bracket. Check the Neal Wright article for details.
vindio
Aircraft Type: C120
Post by vindio »
No extenders on the wheels
I wonder why the official Scott install says AN7-20 (a drilled bolt) but also says to use the 365 self locking nut....
I'm guessing the nut that holds the spring stack together in the front finally gave up the ghost. I check that on every pre-flight. Don't ask me why...... :roll:
I would use a -20A bolt.
I use and undrilled -20A and a metal locking nut AN363-720
Scott tension springs used on your Maule?
What is that mounting angle piece for that I circled.
Check for cracks on your tailwheel bracket where the springs pivoted.
The "what is this for" is the bracket the bolt passes through.
wingspinner
Aircraft Type: c140
Post by wingspinner »
Of course you can just go with the Scott 3200, it’s a good unit you might also consider this: https://alaskagearcompany.com/collectio ... l-assembly
It’s a PMA replacement for the Scott. Read the description to see why you might use this over the actual Scott.
Good grief, senior moment on my part...
Welcome to the club!
