Maule Tailwheel Failure / Scott 3200 Replacement Parts
vindio
Aircraft Type: C120
Re: Maule Tailwheel Failure / Scott 3200 Replacement Parts
Post by vindio »
wingspinner wrote: Fri Oct 10, 2025 6:34 pm Of course you can just go with the Scott 3200, it’s a good unit you might also consider this: https://alaskagearcompany.com/collectio ... l-assembly
It’s a PMA replacement for the Scott. Read the description to see why you might use this over the actual Scott.
My mistake.. I did end up getting the ABI 3200 assembly and associated parts from spruce. Been reading into this stuff too much and confused myself..
My understanding is the manufacturing rights were acquired by ABI from Scott (whoever they were at the time) and no one is manufacturing a Scott 3200 (with the Scott name on it) these days.
6597 wrote: Fri Oct 10, 2025 7:25 pm
The "what is this for" is the bracket the bolt passes through.
Good grief, senior moment on my part...
I wasn't far behind you ...........I had to look ..........twice?
