Searching for a starter clutch
alexallen
Post by alexallen »
I am still using the Delco pull starter and am in need of a replacement clutch. Anyone have an idea where I can get one?
Aircraft Type: '46 140 0-200A
Re: Searching for a starter clutch
Post by 6597 »
https://niagaraairparts.com/
Niagara Air Parts used to be the go to for the pull starters but they aren't advertising it anymore. Don't know if they still service them on the side or not. All I can suggest is to contact them and see.
tonycondon
Post by tonycondon »
my understanding is Niagara is no longer making clutches. they are not servicable in the field, so as they start failing, we all will be switching to light weight starters I guess
N2395N
Post by V529 »
tonycondon wrote: Tue Oct 14, 2025 6:39 pm my understanding is Niagara is no longer making clutches. they are not servicable in the field, so as they start failing, we all will be switching to light weight starters I guess
Yup, this is a "tuff one". I get a couple calls a year on this issue and so far have been un-able to find a source..........
Post by V529 »
alexallen wrote: Tue Oct 14, 2025 2:16 pm I am still using the Delco pull starter and am in need of a replacement clutch. Anyone have an idea where I can get one?
Did you check "marketplace"? Someone in Ohio has a couple of "pull type starters"
Aircraft Type: 48 140 C90
Post by 6898 »
I have a couple 815 695 9970 weekdays
