My mistake.. I did end up getting the ABI 3200 assembly and associated parts from spruce. Been reading into this stuff too much and confused myself..wingspinner wrote: ↑Fri Oct 10, 2025 6:34 pm Of course you can just go with the Scott 3200, it’s a good unit you might also consider this: https://alaskagearcompany.com/collectio ... l-assembly
It’s a PMA replacement for the Scott. Read the description to see why you might use this over the actual Scott.
Maule Tailwheel Failure / Scott 3200 Replacement Parts
vindio
Re: Maule Tailwheel Failure / Scott 3200 Replacement Parts
My understanding is the manufacturing rights were acquired by ABI from Scott (whoever they were at the time) and no one is manufacturing a Scott 3200 (with the Scott name on it) these days.
