Access To Rudder Cable Pulleys Under Baggage Floor
rvaflyer
Aircraft Type: C-140, COL-3
Occupation-Interests: Retired, now flying for fun.
Post by rvaflyer »
Any ideas on the best way to access the rudder cable pulleys under the baggage floor for replacement (other than hiring an octopus)?
Re: Access To Rudder Cable Pulleys Under Baggage Floor
Post by V529 »
rvaflyer wrote: Wed Oct 15, 2025 12:41 pm Any ideas on the best way to access the rudder cable pulleys under the baggage floor for replacement (other than hiring an octopus)?
Welllllll.............. when I was younger and more agile I was able to do it. As I recall, I made/modified a wrench to assist. It helps if you take what little tension is on the rudder cables off when you R&R the pulleys.
Perhaps hire someone very small..........to do the work.
Yes, the two rudder cable pulleys are at the "edge of the universe" ;) at that location. The elevator and aileron are much more reasonable.
