WTB Looking for a set of cylinder baffles for a 140a with 0-200.
qgraber
						WTB Baffles
				qgraber
Re: WTB Baffles
Have you checked Univair, the part you seek $30.58 each. (U10923-000 Univair Intercylinder Baffle).
You might also take a look here also. Has measurements to roll your own.
https://www.cessna120140.com/Forum2018/ ... hp?id=3369
				qgraber
Re: WTB Baffles
So I should be a little more clear on what I'm looking for.  I have the inter cylinder baffles but I'm looking for the one that wraps around from the rear "wall baffle" to the front.
Re: WTB Baffles
McFarlanes has something....Retail price on left but the discounted price on the right.  2024 price list.  Airform is the manufacturer.
				qgraber
Re: WTB Baffles
 - Name: Josh C
 - Aircraft Type: 140A/C90-14F
Re: WTB Baffles
The Macfarlane baffles are made by Airforms.  But are they STC or PMA for 140A's?  As far as I can tell they are not but I would like to know if I'm wrong?
Re: WTB Baffles
FWIW, there baffles are excellent and you can get them pre-powder coated. Did the full set on a 120 at a top overhaul. The little tabs at the front the hook onto the #4 and #3 valve covers are a little undersized so expect to remake those from time to time. But otherwise perfect.
						- 8413
 - Name: Josh C
Re: WTB Baffles
Here is a screenshot of the eligible aircraft.  It doesn't include the 140A.
- Screenshot 2025-11-03 at 6.18.34 AM.png (65.24 KiB) Viewed 88 times
Re: WTB Baffles
https://media.mcfarlaneaviation.com/doc ... g_2025.pdf
Here's a link to Airforms' actual 2025 catalog, go to page 37. There is some contact info you could ask them.
I'm using a pattern from a Cessna 150 Tim Mix loaned me to make some side baffles but I'm adding/cutting and measuring as I go, I have an 0-200.
I'm trying to figure what the dimensional differences are for the 140A that are different. I know there is a different engine mount that moves things about a half inch or so.
