Our 1947 120 has developed a pretty constant ( 1 drop every few seconds) leak on one of the wing fuel sumps. I could make out “CAV -170” so I’m going to order two from aircraft spruce. Just wondering about the process to replace these sumps, is it just a matter of draining the tank and then replacing?
https://www.aircraftspruce.com/catalog/ ... NnCRloG1X2
Leaking Wing Fuel Sump Replacement
vindio
- Aircraft Type: C120
- IMG_4154.jpeg (56.81 KiB) Viewed 100 times
- IMG_4153.jpeg (50.87 KiB) Viewed 100 times
Re: Leaking Wing Fuel Sump Replacement
Did you try new o-rings? Much less expensive.
Yes, drain the tank, cut the safety wire, unscrew the valve. Installation is the reverse.
