Axel Shims
bforman
Axel Shims
Looking for axel shims I have 170 gear legs, and solid 170 axels
Re: Axel Shims
The shims are all the same. You can get ones made by Grove from Aircraft Spruce. I noticed they've become quite spendy...
Sometimes you can rotate or flip some of the shims you may already have to get the desired result. Mine was out because the previous owner had installed them upside down...
- Name: Jeff T
- Aircraft Type: 48 140 C90
Re: Axel Shims
Aircraft Spruce used to have them.
