Sorry to hear of your loss. Thanks for the update.
Removing Glue
Re: Removing Glue
Re: Removing Glue
Ok...........can you specify. Was "Ramp Rat" your father? I'm not certain I understand who you are referring to? Thank youj-3to140 wrote: ↑Sat Mar 07, 2026 8:35 amUpdate:5099 wrote: ↑Tue Mar 26, 2019 8:53 pmI don’t understand the MEK problem. I’ve used MEK for years. Even inside large aircraft fuel tanks cleaning for new sealant. MEK hasn’t bothered me None, None, None . . . . . None! I’m just Fine, Fine, Fine.6183 wrote: ↑Tue Mar 26, 2019 6:31 pm MEK works, but it's nasty stuff, and you need plenty of ventilation plus protection against your bare skin. It will remove the old glue, but it may take several applications. Please don't let your wife touch any MEK she's too good to be around that stuff, but you'll do okay.
John mentioned using some paint stripper, and I have to agree. Try some of that stuff you've used to see if it cuts it.
Is there an echo on this message board?![]()
This was my father, he died from cancer. MEK is not a joke
- 6843
- Name: Dave Sirota
Re: Removing Glue
Some glues respond nicely to xylene
Dave Sirota
'46 C-140 N89654
'67 C-182 N2626R
Formally had '96 Hatz N24B
KRYN
'46 C-140 N89654
'67 C-182 N2626R
KRYN
