150 exhaust and front oil sump nut
Aircraft Type: 140A/C90-14F
Post by 8413 »
Hi,
I just got my engine back from overhaul. My mechanic and I had to remove the oil sump to install the 150 exhaust bracket under the front sump nut. We have turned down a 7/16" socket almost paper thin and still can't get it on the nut to be able to tighten it fully. The sump nuts are MS21044N4 nuts. It seems like when I removed the exhaust bracket prior to the overhaul that the nuts were lower profile than the MS21044N4 nuts seems to be. Is there an acceptable lower profile nut I can use? My mechanic had all kinds of specially modified tools and none of them will work due to the super tight working space the exhaust bracket creates.
Josh
Re: 150 exhaust and front oil sump nut
For the sump I prefer MS21042-4 nuts. They're all metal stop nuts and have a reduced size hex for easier installation in tight quarters.
Technically, nylon stop nuts shouldn't be used on an engine.
Post by 8413 »
Thanks John! That will make installation so much easier!
Josh
Post by 8413 »
The MS21042-4 nut worked great! A standard (no modifications required) 5/16" universal drive socket did the trick. Thanks for your help John Cooper!
Josh
T'was naught!
8425
Post by 8425 »
  • Are those cracks in the weld of the added support and the weld bead next to the nut on the oil tank?
Post by 8413 »
8425,
If you are talking about the left support in the picture (right support if you are sitting in the pilots seat), I think those are shadows from the angle I was holding the light. I looked at the original picture and zoomed and they don't look like cracks to me. I will double check next time I'm at the hangar.
