0-200 gallons per hour....
Aircraft Type: 140A/C90-14F
Re: 0-200 gallons per hour....
Post by 8413 »
David,
Those spark plug pics look great, nice and even for all 4. I assume 2 were front and 2 from back cylinders? Were you running 100LL when you took those pics or mogas? My rear two cylinders run richer than the front two as they are darker than the front 2.
Josh
Post by edidin »
Generally the O200 does make its power at a higher rpm. Here is the comparison from the operator's manual.
O200 vs C85 Power Curves.pdf
(661.23 KiB) Downloaded 1041 times
6597 wrote: ↑Tue Jul 28, 2026 9:37 pm I do have a manifold pressure gauge, why it was installed years ago is a mystery.
Do the logs show it ever had a Beech-Roby prop installed?
Planes with adjustable pitch props will have a manifold pressure/RPM chart to use to calculate power and fuel flow. The RPM/prop load chart we have assumes full throttle operation. There are a lot of variables that affect fuel flow besides RPM. We don't know which ones they speced to get the numbers on the chart.
Check your MAP gauge. It should read ambient barometric pressure with the engine off. At full throttle (engine running) you should see about 2 inches less than baro. Any reading less than that is going to result in lower fuel flow than the chart shows. Any conditions less than standard (29.92") is also going to result in lower fuel flow, including at altitude.
If you can find a copy of the Continental Engine Operator Manual for the O200 it will give you some typical figures for partial power operation.
Here's a chart I found on the 'net. Trust but verify...
O200 partial power chart.jpg (84.01 KiB) Viewed 20822 times
I was thinking over what I said about propeller load meaning full throttle and enough load to bring the RPM down to 2450, or whatever. This is not correct. What it means is enough throttle to turn the prop to the specified RPM. The problem is, it doesn't take into account things like prop pitch, density altitude, climbing, level or descending, draggy biplane or modern, slippery carbon fiber homebuilt, etc.
You can be certain that it takes more throttle to turn the prop 2450 on an engine on a test stand than it does on a plane that is designed for low drag.
So, again, we have too many variables to make a valid comparison.
Ok, I'll weigh in:
0-200 with the standard 69/48 prop for a C-150.
I run regularly at 2500 to 2550 RPM. the only reason is that is the "smoothest" RPM. (I try to keep my engine........smooth)
I see anywhere from 5.9 to 6.3 gallons per hour. The longer flights at higher altitude I can typically get down around 6 gallons per hour.
I get about 108mph at that power setting consistantly.
I do know engines are more efficient at lower RPM and higher manifold (less restriction at the throttle plate).
Fabric wings, empty weight of 950. I usually fly by myself and on trips I top off.
The engine is mid time. Slick mags set at 28 degrees with 21 year old Superior Millenium cylinders. (so "not" the current company Superior but the old one)
Your numbers seem light on fuel usage...........good for you though!
So I flew to Astoria OR today from Pearson KVUO Vancouver, 1.9hr, 9.5gal for a 5gph burn rate.
The gauges looked similar to what I did last weekend up to the San Juan Islands EXCEPT today I was in the 2-3000' altitude whereas last time I was in the nosebleed section 8-9000' .
My vitals today-
RPM 2450-2500
Altitude 2-3000' agl
DA=0-300'
T=55-60F
Cruise manifold about 21", I did check the MP gauge as per John C and it was about as OK as I could tell with ambient.
Other vitals....
Going from 4.5 to 5gph the only thing that stands out is my altitude on the low gph was high and the somewhat higher gph was at low altitude. If anything I think the MP was a little lower on the low gph.
As John thought, I checked what logbooks I have (of course some disappeared from previous owners) and I could not find a Beech-Roby prop installation. No 337 either though I think it's on the Type Certificate so it wouldn't be needed.
Full fuel and me, about 120# under gross. Time to climb to 1000'agl 1 minute 36 seconds.
That makes sense; less air calls for less fuel.
Yes, the adjustable prop needs only a log entry.
Post by 8413 »
David,
Could the difference in gph at the two altitudes be because of slight variations in leaning the mixture? I usually lean till it starts running a little rough then enrichen a bit. What's your leaning procedure?
You must have hit some sink on that last climb as it only equates to around 650fpm and I think you told me you get closer to 1000fpm normally.
Josh
I do the same, the old fashion way. Pull mixture vernier out till it stumbles then a few turns in so it's smooth. My EGT gauge isn't exactly sharp enough to measure the 50F change. Like John says, less air at higher altitudes maybe needs less fuel.
I noted that when I get those 1000+ fpm climb rates they aren't sustainable for long lengths of time. So I thought maybe a time to 1000' may be a more repeatable representation. My CHT tells me when to level off. About 80 indicated as per the book seems to be ideal. What I noticed on climb is that it takes awhile for her to get to a 'sustainable' 80mph and then the climb speed/rate is more steady. I have to learn to not horse it and let it build and maintain speed gently.
I'm still mystified on this one. Do you typically fly .........say above 7000 feet? Have you noticed much difference between sustained cruise at 3000 feet vs 8,000? I've had my aircraft out west multiple times.........Colorado, Montana, S. Dakota etc and I do see better fuel burn out west. I can regularly get below 6per hour, but I'm still not in your numbers.
I had a Mooney for 20 years and when I got above 8,000 feet up to abour 12,000 feet on long hauls I could get get under 9 gallons an hour. I was very happy with that. Obviously a lycoming 360 with adjustable pitch prop, but from the "bomb around altitudes of 3,000 to 5,000 feet, I would typically get 10-12 gallons per hour(depending on depending). Above 9,000 feet I was always below 10 and could drop below 9 per hour.
I wrote it off to:
Thinner air
Airplane was more efficient at those altitudes.
Throttle open farther, less restriction on the throttle plate/MAP.
Second question: Is yours a 46 or later? I put an O-200 in my 47 and struggled with oil temps ever since. (IN Michigan!)
