0-200 gallons per hour....
Aircraft Type: '46 140 0-200A
Re: 0-200 gallons per hour....
Post by 6597 »
Do you typically fly .........say above 7000 feet?
I just did a flight to the coast a few weeks ago, 3-5000', whale watching, regular leaning got 5gph. 2500 rpm. 100-105 indicated. Mostly a mogas blend these days. REM37BY's for plugs. Milleniums with say maybe 250 hours on them.
I don't usually fly too high unless I have some hills/mountains to get over. I'm more in the 3000' agl range.
Is yours a 46 or later? I put an O-200 in my 47 and struggled with oil temps ever since.
Mine's an early 46' with the lower cowl 'lower'. I struggle with CHT's rather than oil temp. The FBO IA said to try and put a sheet of metal across the bottom cut-out to see if it could draw more air thru the top. Results are so-so. I have new side baffles cut out but haven't bent them to fit yet, in an effort to seal up every last little crevice on the sides.
I think Josh may have a point in that the shallow 42" pitch just doesn't really put a lot of strain on the engine in cruise?
6597 wrote: Sat Sep 05, 2026 11:31 amthe shallow 42" pitch...
That's beyond shallow! What is the prop length? What is your static RPM?
Standard prop for a C150 is 69x50, so 69x46 would be extreme climb.
I forget, but, did you post the manifold pressure at cruise? Manifold pressure is a direct indicator of power output for a given RPM. Unfortunately, I've never seen a power chart for an O-200 that relates MP to power.
Post by 6597 »
Here ya go....from a distant past owner. I am guessing he had a 71" prop from his old C85 installation and wanted to use it for the 0-200 installation. Static right at 2400.
Yup, scroll back a few. Generally 21-23 inches give or take. RPMs generally 2450-2500. I wish I did have the power charf/MP for the 0-200. My guess is it's not working too hard. I know that climb props lose in cruise speed a little versus cruise props losing in climb a lot, at least as a general rule of thumb.
Well, bottom line is I expect you're driving around in second gear... Can you exceed red line in level flight?
Post by 6597 »
Yup. Previous owner I think was all about climb performance. Maybe he was trying for the back country thing or considering floats?. I throttle back by instinct when I level from climb out.
Prop History-
7-22-82 overhaul CM71/45 1B90
9-15-82 installed on C85
6-26-84 re-pitch from 45 to 48"
1-25-88 re-pitch unknown spec
9-5-90 re-pitch to 42'
3-14-05 overhaul, 2 stations out of spec, kept 42"
I like your second gear analogy. I did check the airspeed indicator and against the GPS and I'm pretty much in the 100-105/110 range.
Next prop overhaul if I live that long will consider 44"
6597 wrote: Sat Sep 05, 2026 3:22 pmNext prop overhaul if I live that long will consider 44"
There are rules about how many times you can repitch it, and how many changes of direction are permitted. It's already gone from 45-48-X-42 (that we know of). Are there a lot of numbers stamped on the hub?
Post by 6597 »
I think I'll check the serial number. I'll also look at the old prop logs for that unknown pitch. I only see a 44 to 42 change here.
Post by V529 »
Hmmmmm, very interesting info..........I'll bet your prop has something to do with it. I don't recall seeing/hearing of that prop on an O-200.......
Post by 6597 »
It's on this doc...
P-842PropTypeCertificate.pdf
(27.08 KiB) Downloaded 39 times
6597 wrote: Sat Sep 05, 2026 5:44 pm It's on this doc...
It's approved (tested) by McCauley, but I don't know of any plane that was originally certified with one on an O-200.
