I am in need of a winterization kit for our "new" 140. Is there anyone out there who would be able to make the covers for the two case cooling holes and the front grill shields? Or, if you have the kit laying around and would like to sell it? Just let me know. Please contact me at remhof@q.com or give me a call at 651-457-1554.
Cheers,
Marc
Winterization Kit
8186
- Name: Marc Remhof
- Name: Raymond H
Re: Winterization Kit
So are ours the same as the 170s?
8186
- Name: Marc Remhof
Thank you both for the reply to my request for a winterization kit. The search is complete.
Cheers,
Marc
Cheers,
Marc
The cowl inlet covers are the same for the 120/140 and at least the early 170s.
The cover for the oil tank is available from Wag-aero. https://www.wagaero.com/oil-tank-cover-kit-4-5-qt.html
- Name: Marc Remhof
Disregard this post. Problem has been taken care of.
Marc
Marc
- 8233
- Name: David Freeland
- Aircraft Type: 1946 C120
I've read mixed reviews on the oil sump/tank covers in terms of if it really makes any sort of difference. The other items on the winterization kit seem totally logical but the cover doesn't look that substantial. Does anyone have any first hand experience to share if the cover is really worthwhile? I'm assuming if I have a sump heater that it would be a bad idea to put a cover on the sump?
6643 wrote: ↑Thu Nov 15, 2018 5:37 pm The cowl inlet covers are the same for the 120/140 and at least the early 170s.
8186
- Name: Marc Remhof
I posted some updated information on winterization kits on another part of the forum. Brian Stansbury, 641-642-3151, is able to make the Grill Winterization Covers along with the Nose Cowl Vent Plugs. You will need to find/make and install the Grill Cover Springs as listed on pages 122 and 123 of the parts manual. According to the 170 information, the springs are make from 3/16 stainless steel wire (welding rod?) Information on making the springs can be found on the Cessna 170 site. He is selling the kits for $150.00.
Looking forward to getting my set installed on 140 "Marvin".
Cheers,
Marc
Cheers,
Marc
8186
- Name: Marc Remhof
Quick correction. It has dawned on me that the 3/16 ss listed on the C170 drawing for the winterization kit refers to spring steel wire and not stainless steel. Sorry for any confusion. I'll try to post some pictures and soon as we get everything in place.
Cheers,
Marc
Cheers,
Marc
8186
- Name: Marc Remhof
I was corrected again. One of our members says the wire is 3/32 and not 3/16. That makes much more sense.
As for being the same as 170 covers, call Brian. He measured both before making the set for me.
Marc
Marc
