What have folks done and what should avoid. This would be a power receptacle for my tablet/phone. Thanks
Joe
Installing a lghter/power socket
- 8170
- Name: Joe
6298
- Name: Randy Thompson
Re: Installing a lghter/power socket
Cigarette lighters are to be fused at the battery, not the power buss.
- 8170
- Name: Joe
Roger that Randy. I was wondering if anyone has a particular socket they have used and if they went 337 route or logbook entry. I would think a logbook entry would be appropriate. Thoughts?
Joe
Joe
8209
- Name: Brent Wilson
I need to install one in my 140 as well. Could you expand on the installation a little more please? Fused at the battery? Which side of the solenoid? A wire run all the way from the battery with an inline fuse all the way to the panel? Wire size?
Thanks, Brent
Thanks, Brent
6298
Most people would like the port to remain hot with the master off, so it would go to the battery side of the solenoid. It has been quite a while since I did my last one. I think I used #12 wire with the inline fuse at the battery. The fuse needs to be a lower amperage than the capacity of the wire.
8209
Thanks for the info Randy. I will give it a try.
- 5099
- Name: Ramp Rat
Wouldn't AD 79-08-03 and AC 43.13 shed some light on the subject???
JMHO, Steve
JMHO, Steve
America, Love it or Leave IT!
I'm pretty certain any time there is a cigarette lighter in our aircraft, that AD applies. I would recommend getting a Cessna receptacle and making a log entry stating the receptacle was installed and circuit protection was added.
