You are right; the original covers go on the inside of the cowl. The hooks should be just long enough to clear the "grill" when the spring is completely compressed.
I think if I were making a set I'd make them flat and put them on the outside. Easier to make and less stress on the grills. But, in reality, I have just used duct tape...
Winterization Kit
Re: Winterization Kit
- Name: David Freeland
- Aircraft Type: 1946 C120
Makes sense. I bought a set from Scott Dennison which uses a small plate on the outside and bolts that connect through the grill with the original style covers on the inside. They are not particularly fast to take on and off if you have an unexpected warm day for example. The spring hooks seems like they would be must faster but as you mention, perhaps not as kind to the grill.6643 wrote: ↑Sun Dec 16, 2018 8:47 pm You are right; the original covers go on the inside of the cowl. The hooks should be just long enough to clear the "grill" when the spring is completely compressed.
- Name: Brent Wilson
I have seen the drawing that John posted. I was wondering if anybody had an actual picture of the winterization kit on the airplane.
- Name: Joe Belany
- Occupation-Interests: Flight paramedic
Mine are installed. If I get out to the hangar tomorrow I will snap a couple of pictures.
Joe
Joe
Joe Belany
2470V
2470V
Thanks Joe, that would be great.
