replacing side windows
6656
Aircraft Type: 1946 C140
Occupation-Interests: retired physician
Post by 6656 »
I need to replace the side windows, the plexiglass is in poor shape. Suggestions as to how to do that?
6656
Post by 6656 »
Probably should mention it is a 1946 C 140
8231
Occupation-Interests: hobo
Re: replacing side windows
Post by 8231 »
Door or rear windows?
6656
Re: replacing door windows windows
Post by 6656 »
The door windows Plexiglas is in poor shape on a 1946 140. How do I go about fixing that. Replace the whole window or take off the frame and replace the plexiglas?
Post by V529 »
The frame is removable, then you can replace just the plexiglass.
You have to drill out all the rivets around the edges.
Aircraft Type: 1946 C120
Post by 8233 »
6643 wrote: ↑Sat Jan 12, 2019 9:35 am You have to drill out all the rivets around the edges.
John, I was looking at mine the other day and considering replacement as well and saw those rivets. From a tool perspective, how do you get new rivets in there? It just doesn't seem like there would be any room to work with a rivet gun and bucking bar. I'm sure there's a solution, I'm just ignorant to what that would be.
David Freeland - CFII
Post by 5115 »
8233 wrote: ↑Sun Jan 13, 2019 10:09 am
Pretty easy to do with a 'Rivet Hand Squeezer'. Check Spruce for different models. Did my windows and it was not very difficult.
Martin Tanguay
Post by 8233 »
Ahh, thanks! I knew there had to be something out there for that.
6656
Post by 6656 »
I've seen adds for "Bubble" type windows. Seems to me that it might have a distortion problem. Any experience with those?
