Patroller door mod
8264
Aircraft Type: C120
Re: Patroller door mod
Post by 8264 »
Finally started this project today! Whats the best/correct tool to make the z channel pictured below? I bought a portable metal brake a few weeks back thinking that would be all I need for bending the sheet metal, I've come to realize I can't bend the metal that tight.
Post by 8170 »
Looks good. Hope to get back to mine soon.
Post by 8170 »
As far as the Z channel goes I was looking at possibly using extruded channel. McMaster Carr has it in 2024 and 6061
I'm not sure why you couldn't make that channel on a brake. Maybe you just need to hunt up the right brake for the job. Otherwise, a set of roller dies will do the trick, but you might have to make your own.
8264
Aircraft Type: C120
Post by 8264 »
I think I found a brake that will work, eastwood sells a brake called the versabend that looks like it would work, it allows to get a lot tighter on the bends. Just hate to spend the cash right now after buying the other brake.
I'll take a look at mcmaster carr and see what they have too.
I wouldn't recommend buying a brake just to make one piece. Try a HVAC installer or a repair shop at the airport.
8264
Aircraft Type: C120
Post by 8264 »
My thoughts exactly. I'll hunt around and see if i can find one local to use
8340
Post by 8340 »
I would really appreciate the patroller door drawings as well. I worked with a 150 owner that had the patroller doors and they look amazing.
Joshua
8264
Aircraft Type: C120
Post by 8264 »
8340 wrote: Thu Dec 06, 2018 10:57 am I would really appreciate the patroller door drawings as well. I worked with a 150 owner that had the patroller doors and they look amazing.
Joshua
Send me your email and I'll forward the drawings and some pictures I saved off the old forum
8271
Post by 8271 »
8264 wrote: Thu Dec 06, 2018 11:22 am [quote=8340 post_id=2073 time=<a href="tel:1544115472">1544115472</a> user_id=973]
Joshua
[/quote]
Hi there,
I’m thinking to do the same mod on my doors too, can you forward the drawings to me too by any chances ?
Many thanks
Lio
liomgl@me.com
